Jfreeman1412
Yes 1973 Trojan with 318's. The carbs are 1409 4 barrels. Oh sorry I believe they were four barrel Carters. I will look for a pic of them.
Is the accelerator pump giving it a good shot of fuel when you goose it and did you install a new carb gasket when you mounted the carb. Use a piece of vacuum tubing and put one end to your ear and search around the intake gaskets with the other end with the engine running. Put the end in the carb so you know what to listen for. That will help you locate and isolate any vacuum leak that may exist.
Thanks Jeff.
Noelct....I have not checked the timing. What or why does that come to mind? Thanks
I defiantly took your advice with 1409's and have two new ones now. That was an old video to confirm the old ones were four barrels as well. I am convinced it is not a carb issue after swapping the carbs with similar results.
I think I will:
1. Check the Timing
2. Hook up a external gas tank to the fuel line right before the fuel pump.
3. Change the fuel pump
4. Re-access the situation
Generally if it worked a couple weeks ago, it probably will today.
I disagree. Your starter works fine until the day that it doesn't. Then you're stuck at the slip.
Many engine parts let go without warning. Just because it was running fine last weekend, doesn't mean you should rule out any possibility.
-JJ
http://www.marineengine.com/boat-forum/showthread.php?390716-M440-Starter-Bendix-DriveGood post JJ!
There is no plate to check the timing on this engine. Does anyone have any experience with this, or is there a work around? Took it out and can get it up to 2100 RPMS and same thing.
I found the mark. But cannot locate the numbered gauge. What part O the front of the engine? Right above the pully?
Did you verify that each ignition wire leads to the correct cylinder, i.e.. check firing order? (You must have done this if you replaced cap.)
You should see a timing mark(s) (scribe line) on engine damper (the 6 inch diameter disc bolted to front on crank shaft) that lines up with a numbered gage which should be located about the 2-o'Clock position on front of engine...
And/or on the rear side of engine under the rubber flap located at the 12 o"Clock position that times off of flywheel.
When you had fuel lines off to install your new pump, did you back blow lines clear?
Do you have a timing light?Thanks for the info in the flywheel flap. Now how do I time it off of that? I also found the scribe mark on pully in the front of the engine. Can I get some instructions on how and what to do? Thanks again everyone.
Pull trigger on timing light and aim at timing gage.
I still believe your problem is with the single fuel pickup. Have you tried running one of the engines on a portable tank yet?
