Where is my neutral switch on my 1984 Bayliner 5.0 with the 275 outdrive? Ricardo rebuilt my transmission last winter and I finally got to take it out and run it. It ran fine, shifts fine, until I got too far down the lake and it would not start or shift into reverse. I got a chance today to investigate and the brass shift mechanism was tilted slightly clockwise and the prop would not move. I disconnected the linkage to see if I could manually shift the brass shifter. It was stuck also. I reached down with my foot to see if turning the prop would allow me to shift and the prop broke loose and the shifter moved to neutral. Now the shift lever moves forward and reverse effortlessly (not running) and I checked the linkage. Adjusted it slightly to better represent neutral but when I went to start it I get nothing at the key, no starter. I took a screwdriver to the starter to see if it turns the engine over and that works fine. So, my choices are, ignition switch and neutral switch. School me on what and where the neutral switch is located and where I need to troubleshoot. I haven't had the opportunity to visit this forum for a while but this is the place for answers. Oh, Rick, the oil in the outdrive looks great, I need to add a little but there is no water contamination so your advise to do the air pressure check worked. Thanks!
