"Well, here's some real es
"Well, here's some real esoterica for those in the know. In the midst of cleaning up my project 15hp Mariner (1990 model), I noticed this:
Mariner 15hp starter bearings"">
That is to say, one of the needle bearings in the recoil starter sheave hub seems to be missing. The picture sucks but you can see the empty space to the right of the 3 bearings.
I presume this is a bug and not a feature. But is it, and if so, is there anything I can do to fix it short of replacing the whole starter? The sheave seems to rotate ok on the flywheel nut stub shaft, but I'm not really happy about missing a needle bearing in a part that's under continuous high-RPM rotation.
By the way, while we're on the topic, can someone explain the mechanism by which the starter only rotates one way on the stub shaft? Haven't been able to figure this one out.
Or does it have something to do with this "missing" bearing?"
