Ricardo, there is a set of DP lower gears listed on e-bay that say they are for a 1.95:1 or 2.32:1 both.
I questioned the seller asking how they could be both and he replied "the lower gears are the same and the difference was in the upper gears". Is this possible? I don't believe it is. I know the overall ratio is a combination of upper and lowers but I think we may be talking "apples and oranges".
NEW Volvo DP dual prop gear set 3851309 1.95:1, 2.32:1 #110790431216
Thanks, John
This thread implies that we're talking about an AQ series drive.
All AQ series transmission reduction is the same. The ratio change occurs in the lower unit.
The tooth count between the "drive" gear and the two "driven" gears determines this ratio.
The smaller drive gear and the larger the driven gears = a greater reduction.... and visa-versa.
These gears cannot be mixed and matched.... even with the same ratio part number, as they are factory matched (as a set) during fabrication.... just like an automotive ring/pinion gear set.
Is this the auction?
http://www.ebay.com/itm/NEW-Volvo-D...431216&pt=Boat_Parts_Accessories_Gear&vxp=mtr
He lists more drive numbers than what the gear set will work in, so perhaps he has many to choose from... AQ and DP-S styles perhaps.
FYI: the set up time can require anywhere from 6 to 8 hours, and special tools and skills are required, not to mention the cost of bearings/seals.
Often it's not cost effective to change a perfectly good working gear set to another ratio.
Instead, off the one that you have, and pick up a good one with the correct ratio.
Re-shimming of the vertical shaft bearing race must be done when swapping any lower unit from one Intermediate to another.
No exceptions!
