................... As for the starter, I have two heavy red wires coming from the battery and 50 amp circuit breaker and a heavy orange wire from the alternator to the starter. All three go on the same post with a yellow/red wire to a small post.
No ground that I can see near the starter.
Yes, the starter tries to turn the engine over but acts like it does not have the power. Yet it does not "click" like a dead battery. It goes "clunk" when the starter pushes the bendix out.
Ricardo- The starter is brand new but yet it could be "factory defective". It is a pain to get out without pulling the engine. Speaking of which, it has two bolts. One is long and one is short and they are offset. The bolt nearest the starboard side is tight against the flywheel pan. It is against the pan so tight that I cannot put a socket or box end wrench on it. Does this seem right? Is it possible to remove the flywheel pan without pulling the engine out or taking the starter out? Then I could look for anything binding up. I am hoping to take the starter off this weekend and have Auto Zone test it.
Thank you, Bob
Bob, based on what you've posted above....., I see nor hear of any "Common" cable connection to the main lug on the starter motor.
This would be a heavy gauge battery cable.... aka "Common" cable!
The red and orange
wires (not to be mistaken for cables) that you speak of, are part of your engine harness and charging circuit.
The "Common"
cable that runs from your MBSS (main battery selector switch) must make a direct connection to the main large terminal on the "Solenoid".
The same location as what your charging circuit connects to!
(while this is showing an Outboard, you'll get the idea here. The "Common" connects directly to the solenoid terminal labeled "B" in the next image)
If you have an alternate means of powering your engine harness, and if this common cable is absent, there is your problem!
(this schematic is not necessarily Marine, and it does not show a charging circuit. Where it shows "ignition switch", insert the words
"starter solenoid" circuit, of which will be your
yellow wire.)
BTW, this style starter motor does not use a Bendix drive.
Also Bob, if this new starter motor is not one of the HTGR/PMGR units, it would behoove you to return it, and purchase a HTGR/PMGR unit. They will outperform the other style, hands down. Much smaller in size, and much easier to R & R as well!
