need_4_speed
I realize I may have posted th
I realize I may have posted this in the wrong area yesterday. I apologize.
I found the serial # on this mystery motor. It's 2480805. It says 1100 with 2 lightening bolts. Does that mean its the 1100ss model? It also is a short shaft. I have redone all the wiring in the motor. What other componants should be replaced? I also checked the lower unit oil and it looked OK. I was told that all cylinders had 125 comp. except one which had alot less. Would that be rings or a leaking/blown head gasket?
What else can you tell me about these motors? I appreciate all the info. MIKE
