Hi guys,
Im hoping you can steer me in the right direction. I've got a 2001, 90 hp, 2 stroke, looper, vro, etc.
It ran great for the last 3 years, since I bought it. *I rebuilt the carbs when I bought it because they leaked fuel badly(float bowls) and its run great since.
So, anyway, ran great but has now got a problem. It will not idle without me raising the Throttle only lever high. then it will start and idle at rpm's over 2000, otherwise it dies. It will run over 2000 rpm, but misses and sounds rough. Under power, I can get it up close to normal WOT rpms, but it will still be missing, and hesitating throughout.
These symptoms came on over a weeks time. Sometimes it would idle fine, other times, not. Now it won't idle under 2000 rpm.
The gas is new, and I replaced the fuel/water filter, and fuel line and tried running it on another fuel tank with no change, so I believe the fuel supply is good.
I'm hoping someone will help guide me through. I'm very capable of doing repair work but Outboards are new to me.
Thanks.
Thanks.
