Howdy.....after Skooter posted his worn out, rusted idler pulley I decided to check mine. Little did I know that what I thought would be a simple job, ended up with me dropping everything after 4 hrs and walking away......before I had a meltdown. Very aggravating.
As soon as I loosened the tensioner I heard the click, and then another. I knew right then that the belt had jumped teeth. I figured no big deal. I'll just align the marks as the manual said and.....presto. It's turning out not to be so easy because the "driven" pulleys want to "jump" past the numbers, I assume because of the valve springs.
What's the trick? The manual doesn't provide helpful instructions that I can see.
