JustCasting
So I had a worn bearing carrier that would not take new seals due to its condition and major water intrusion. So I decided to rebuild both of my out drives this winter.
I was able to use a puller the remove the carrier with the shaft in the outdrive, so I am trying to reinstall the unit back onto the shaft. If this is not possible just let me know.
I ordered 2 new carriers, and both the main and needle bearings and seals. I was able to get them all reassembled and thought I was almost done with the job and am struggling to get the carrier back onto the shaft.
The 2 flat bearings that are 2 halls of a circle that install into the reversing gear are stopping the carrier from sliding onto the shaft. And have been trying to use the prop shaft nut to drive it onto the shaft with no luck.
looking for some help from people that have done this job before.
Troy
Troy
