Found the Part # 16.11-08290....Does anybody know if you can replace just the Ring Gear on this Flywheel or do have to replace the complete Flywheel....Mine is still installed but I can see that a couple of teeth are missing and its slowly starting to chew up my Starter drive pinion gear..... If you can replace the Ring Gear how much work is it and do you need special tools????? Would be great to here your thoughts on this problem. Thanks
Johnscott
Johnscott
