JohnGinsberg
Need help. My starboard engine is a 1988 Mercruiser 7.4 (=a chevy 454) with a Thunderbolt IV ignition system. Last time it ran well was last October 31. On that voyage, it started running rough. We have done a lot of work on it (see below) and it starts very well, but the engine will not rev up at all when I throttle up, and the timing will not advance.
We have:
- run a compression test on all cylinders: OK
- replaced the fuel filter: no H2O in fuel
- checked fuel pressure: OK.
- replaced distributor cap and rotor and ignition sensor
- replaced plugs and plug wires
- replaced the ignition coil
- rebuilt the carb and then switched good carb from other engine to double check that there is no carb issue.
- tested the whole ignition system, including the ignition control module, using (1) the diagnostic flow chart in the factory manual (copied here: http://www.marinemechanic.com/site/page251.html); and (2) this test from iboats forum (see post #2, by dubs283: http://forums.iboats.com/mercruiser...ives/apha-one-v6-thunderbolt-iv-444003.html): all OK, except timing issue noted above (no advance).
I have spark at every post on the distributor, at the end of each plug wire, and in each plug. I am stuck. Boating season is passing me by. This is my first full summer as a boat owner and liveaboard. Very, very frustrated.
John Ginsberg
Gangplank Marina
Washington, DC
We have:
John Ginsberg
Gangplank Marina
Washington, DC
