Mystery leak on a 1995 Celebrity 18” Runabout with a 4.3LX/V6 Alpha One sterndrive.
1995 Celebrity 18” runabout with a 4.3LX/V6 Alpha One sterndrive.
Engine serial number OF590542
Transom serial number OF574323
Drive serial number OF521054
Engine only has 227 hours on it. Bought the boat from a neighbor in Arizona four years ago. He had it sitting for about 15 years, thus the reason for the low engine hours. Before I bought it, he had the seals replaced on the outdrive. The U Joint bellows, shift cable bellows, etc. have been replaced and appear to be in good shape. No cracks or brittleness are observed.
I am getting water in the bilge, and I cannot figure out where it is coming from. It appears to fill up faster if there is significant weight in the boat. Six big guys Vs my wife and I in the boat alone.
I have tried the following.
I hate to pull the whole outdrive and replace the seals when they look at feel OK and still have the leak. The one really fully thing is it seems to leak more when the boat is loaded with 6 people just 2. This could be a red herring but the only difference I see is that I cannot explain.
Please give your expert suggestions. I will try a few before redoing the whole bellow’s replacement.
Mike
- Check the outdrive bellows for cracks or brittleness. Didn’t see any. Felt areas I couldn’t visually check. The rubber seems pliable with no felt cracks or splits. (seals were replaced less than five years ago)
- Run the engine for 10 minutes with a water hose to the outdrive and check for leaks. Don’t appear to be any in the boat.
- Filled the bilge with water just below the starter and raised the front of the boat on the trailer to the max and looked for leaks around the transom. Didn’t see any leaks or drips. I only filled it to below the starter.
- Put the boat in the water and crawled back there to look for a leak with a good 12V trouble light. It is really hard to see but I could tell water was coming in slowly but couldn’t figure out where it was coming in the bilge.
Mike
