Hi all.
Two parts to this post, sorry.
There is quite a lot on alarms here and it is all really helpful. However I am a little confused about something that has started happening to my BF130.
I changed the thermostat this week and cleaned the overheat sensor at the same time. No particular reason. There was a lot of salt and deposit in the tell tale so I assumed this was choking the system. The thermostat was very clogged. I flushed through the system with fresh water (as I always do after boating) and also flushed through with the thermostat removed.
Back up and running and I get an alarm when idling. Long intermittent, both ACG and PGM lights on permanently. As the alarm kicks in the engine idle rpm climbs a little.
The oil light is green and there is no hot water warning.
Switch off the ignition and restart clears the alarm but it will soon return on idle. At high revs underway it does not appear to alarm. The alarm also occurs shortly after cold start.
I am trying to get the diagnosis by light flashing through shorting the Diagnostic but being new to electronics I expect I am doing this wrong.
I came back to the engine after 12 hours having pored over the forum and had not done anything to make the alarm occur (restart) but just shorted the terminal and switched on the ignition. No lights flashing just the usual ignition and the double beep etc.
So would anyone be able to tell me the correct way to get this self diagnosis to happen?
Or would anyone want to hazard what might be the problem? From the helpful post by Chawk man it suggests this alarm isn't cooling related... is that a fair call?
Secondly, I am still getting salt crystal like debris coming through the telltale which frequently blocks with it. There is a new impeller however and when I remove the plastic tee which leads to the tell tale outlet I have good pressure there. So any tips on REALLY clearing the cooling system would be appreciated too!
Apologies for the lengthy post. Summer is here (kind of) so this is a frustrating niggle...
