bagpipeswest
I get the boat back and she te
I get the boat back and she tells me that the boat would not go into fwd or reverse and then it started to over heat. The boat is a 120hp force L drive. the prop is bent and the fin below the prop on the lower leg is broken off. The nut that holds the prop on was so lose you could pull the prop out a 1/4 inch. The nut is not stipped
Can I get a lower leg for it?
Can I weld a new piece on?
What else did she break inside the leg
what kind of tests should I do
