oldblueband150
"Hi all,
I have a B
"Hi all,
I have a Blueband 150 and the motor will rise up when put in reverse. I have the old style pump with the single solenoid.
I have tried screwing the reverse lock dial all the way out then all the way in with the same result.
I know you cant get parts anymore but what is it inside of the pump housing that fails?
It trims up ok and holds, trims down but it only seem to release pressure, not "pump" it down.
Is this bit normal? Could it be possible some one has had it apart and forgotten a check valve, spring etc?
Can i use a different pump to operate my rams?
Cheers,
Kris"
I have a B
"Hi all,
Cheers,
Kris"
