motor kicking up when going foreward
mark4470
My 125 hp force outboard kicks up when I am going in foreward?? It seems to get worse the higher the RPMs does anyone have any suggestions to the cause of this:confused:
Does your tilt system work as it should??? Raise up and down with out any problems?? It all mosts sounds like you might have a problem with the tilt switch or the tilt switch circuit or one of the relays, like maybe the motor is raising on it own when your going along. I would start with the tilt system electrically and see if you find anything.
yes the boat definetly goes foreward, and the tilt systems work properly, could it be that my prop is slipping and then it engages??
