JedPHannigan
Ok so I have an 82' Johnson 70 hp. It had been parked for about 6 years covered. It ran fine before I parked it only lower unit problems. So I have pulled it out of storage and replaced the lower unit, new batteries, and rewired most of the boat.
After this I tried to crank it with surprisingly not much problem. To me it sounded fairly good "I tought" with the muffs. It tached up but sounded like a little sputter at mid to higher rpms. I took it to the lake to test it out but it wouldn't gain speed or tach up in the water.
After research I figured it was gummed up carbs. I rebuilt the carbs, replaced the fuel lines, and filter. Still same problems. I then pulled off the carbs three separate times letting them soak then cleaning again. Still the same problems.
I then began to feel it was a firing problem. I pulled the plugs and checked for spark each appeared to be fine. So I replaced the plugs. I took it out again same result "to start with" this time it ran the same then I wasn't expecting it but suddenly it ran awesome. Then suddenly it went back to the same thing.
I then replaced the coil packs, wires, and plugs. After everything I am still in the same situation and scratching my head. I have done lots of research to get this far with it because I am VERY far from a mechanic. I am still researching and am possibly leaning towards the rectifier or possibly gummed carbs I missed but I doubt it's the carbs and long and as many times I've cleaned them. Btw when I pulled the plugs even the new ones at least one or two were darker. I have found just buying parts can get to be expensive so if anyone has any ideas I would appreciate any help.
thanks
thanks
