What model outdrive do I have on this old boat and what length does the trim cylinders need to be set at as far as upper limits?Had a bad limit and sending switch on it when I got it.Ordered the limit switch and didn't know the sending switch was bad also until I went to install the limit switch.Is the sending switch even needed if the boat doesn't have a trim gauge?It's on my to do list in the near future though.Any way, there was three different pictures in the instructions of different cylinders, but the eariler picture didn't look like my cylinder, so I went with the ALPHA ONE and set limit to 20 3/4"..Figured the earlier model should be what I needed, but it was shown inverted and looked too round .Alpha One looked more like what I have.Up-dated maybe? Sure isn't as much rise of drive as I thought it would be..(4.5")Does that sound correct?Serial number on gimble is all but worn off..Looks something like maybe COOO 51, but I can't tell for sure...One more thing.I can't locate the grease fitting for the gimble bearing. Can feel the shaft but just aint alot of room back there. Will try again soon.Thanks Again for the help!
