Barney Rubble
Hey folks
I'm hoping to get a chance to run up this motor on the weekend, after a period of non-use (2 years or less), can you advise on the correct oil/fuel mix; I'm using Pemco TC-W3 spec oil, suggested is 50:1. That sound OK?
When checking battery charge voltage, what figures ought I to see, at say idle, mid, and max RPM? I know there is no regulator as such, so presumably the battery will be a load to soak some output up?
I have an infrared laser thermometer, can anyone advise specific or ballpark figures taken externally at various places, with air temp. c.17deg C, and how to check the warning system (light and/or alarm)?
Also, the wisdom (or not!) of using an ethanol free fuel, like Aspen or the like, as the 'last supper' fuel before putting the motor into store? I'll be using Sta-Bil when it is in use.
Thanx for taking the time to help me out, I'm sure more questions will follow, and I certainly do appreciate the help. Cheers'n'beers!
