ranger5873
J150GLEDB 150 Faststrike 96 MY. Had an issue earlier this year with it being in SLOW mode. Replaced both T-stats as well as port and starboard temp sensors. That did the trick. Fast forward to more recent time..went a few times and ran great but at WOT all it would muster was 4500 rpm. Prior to the SLOW mode deal she ran around 5500 and speed was on in mid 50s. 2 weeks ago I dumped the boat in and took off and zero hole shot. Pushed water for a hundred yards or so but finally broke over. Ran great aside from the 4500 rpm limit. Later that day I left the marina and it died. Bulb was soft. Went to prime it and gas spewd everywhere. The fitting cracked and broke that runs through the front of the midsection. Rigged it to make it home. Thought maybe that was my issue fuel/air leak. Went out today and no difference. Zero hole shot and low WOT rpm. Bulb stays hard. Ideas? She used to hop right up and be on pad in a short amount of time. Coils, power pack stator rectifier plugs wires optical sensor all less than 2 yrs old. Fuel pump a year old, filter new as well as primer and hose. Anti-siphon valve maybe? Stumped.
