Got it out on the water for the first time this morning after replacing impeller and thermostat. Was peeing when we started but after 10 or so minutes I looked back and it had stopped. We fished for an hour or so and when we cranked back up it started peeing again a little bit, gradually getting stronger then went to just a drip again. I brought it home popped the hose that goes to the pee valve off, blew into it then hooked muffs up cranked it up and she peed like a champ. The water coming out was pretty warm I assume that’s normal? Is there any permanent fix for the intermittent peeing?
Issue #2, top cylinder is not firing, compression is good (per mechanic), swapped plugs and wires with the other two cylinders and that didn’t change anything, so assuming it’s a fuel/carb issue. Would it be ok to do a “decarb” treatment with just the muffs supplying Water or does it need to be in the water or would a decarb even do anything for me? Any suggestions would be greatly appreciated.
