milky trans fluid
capemaydiamond
hey guys i just fired up my port side new engine with a used v drive and ran it for about 5 minutes, but when i turned it off and checked the trans fluid it was milky. could it be the cooler or something else and how do you drain the fluid in a v drive? thanks.
Sounds like you cooler is allowing water in. You need to move fast here! Replace the cooler and drain/ re-fill/ drain until the fluid looks good. Delay and you might have to rebuild the tranny.
Jeff
