Hi Guys,
I have a Mercury 115/80 outboard jet with Big Tiller. Serial#2B805424 with 119 hours on it. I have had the boat for 2 years with no issues until recently. I was driving back and nearing the dock when I ran out of fuel. Put new fuel in, primed bulb turned key on and off a few times to prime and cranked right up. Next time out, after about 6-8 minutes of driving 3/4 to max RPM the engine started to sputter. I took it to my mechanic and we changed the following with no success. The motor will start, idle and run fine below about 20mph. After running max rpm for 6-8minutes it will start to sputter. I am not sure the running out of fuel has anything to do with this or if it is coincidental. Below is a list of what has been changed so far.
-Fuel Filter, (both)
-Fuel Lines
-Prime Bulb
-Flushed tank (Aluminum tank)
-New low pressure pump
-New Spark plugs
-New oil change & Filter
-Water pump
-Spark plug wires & Coils
-Also tried running it with trim sensor unplugged but no change occurred.
After this I hooked it up to dealer computer and engine showed no codes or faults. They told me to run the engine and see if any codes appeared while doing so. I ran the motor using my vessel view and engine threw no codes while sputtering. RPM max was 5,750-5,800, fuel pressure was 40ish, engine temp was 136. Everything appears to be fine and engine is not throwing any codes. At this point the mechanic, dealer and myself are stumped. Any ideas or troubleshooting we can try? It sounds as if someone is turning the key on and off while i am driving and it only occurs at the 3/4 to max throttle range. Other thoughts are kill switch, neutral safety switch?
T.I.A.
-Fuel Lines
-Prime Bulb
-New Spark plugs
-Water pump
T.I.A.
