Yinzerofthree
Hello everyone! Thanks in advance for reading! I am the proud owner of a Mercury Mariner 9.9hp motor. Motor has always run well for me (knock on wood) since I bought it four years ago. The owner I bought it from knew little about the motor. So I was hoping the helpful people on this forum may be able to help me with a few things. When I took the motor off to bring into the basement for winterization I noticed a lot of water in the lower unit oil when I drained it.
1. Would anyone be able to identfy the model year of this engine? The I attached pictutes of the paint scheme and the made in Japan stamps as well as some other stamps from the inside of the engine. I am happy to provide any more pictures people would need. There is no serial plate on the engine, or any serial number I can locate. I would add I bought a water pump from this site ([FONT="]18-3148 - Water Pump Kit 46-84277T) which fit like a glove if that offers any more insight.[/FONT]
[FONT="]2. Would anyone have any thoughts on what is causing the water in the lower unit. I had the water pump changed by a local memeber of my antique motor club last year, and the impeller is pumping water out the pee hole stongly. I ordered new 3/16 lower unit oil screwss this fall and they did not fit in the screw holes. Does anyone know what size lower unit screws fit this model? The crushable washers look a bit worn and I would like to replace[/FONT]
[FONT="]3. I pulled off the prop and did not notice any signicant issues or wear in any of the seals, nor did I see any fishing line on the prop.[/FONT]
So thanks for reading, and I would love to hear any insight anyone has!!
