Re: Mercury Lower unit
No site that I know of, but -
Any 6, 8, 9.9 or 15 horse Mercury or Mercury/Mariner lower unit from any model built between 1986 and 2004 will bolt right on.
However, the water tube assembly and the exhaust plate was changed on the 1995 and newer models.
So if the lower unit comes from a 1995-2004 model you would also have to change the exhaust plate (between the powerhead and the leg).
It's not as big a job as it sounds. The new plate and 2 gaskets required run about 60 bucks and the powerhead is removed as a totally intact unit - so it's 6 bolts and a nut to remove and about an extra hour of your time...
