Is engine running at normal temp, telltale stream should be warm when she is warmed up, Do you have to leave the choke on fulltime for it to run,or use choke just to restart and then push it in once she fires? What does the plug look like when this issue arises? wet? Dry? Is primer bulb going flat? Possible air leak in fuel lines?
