Mercury 4hp 2stroke outboard gearbox top up
knocker8
On you tube videos it shows 2 screws. One to drain the oil and one for the top up level. My engine does not have these screws so what is the top up process and with what
FWIW, you'd likely get more thoughts if you would have posted in the mercury outboard section....
That said, I've never seen a mercury without the two screws in the gear housing...one down low on the bulge where the prop shaft goes and the other up high above the anti cavitation plate...
