"Do the waterpump now that you
"Do the waterpump now that you know how to get the lower off. The impeller is less than $20, you can buy it here if you want. Remove lower, undue 3 7/16 nuts on plastic housing and remove. Slide off old, install new impeller on key, lube with vasoline, slide housing down on top impeller while turning drive shaft clockwise, re-assemble.
When you need help with the link and sync, just ask. The base timing is 3 degrees + or- 1. Don't mess with the stops on the exhaust plate, they are set at the factory. Open throttle all the way and look down carb, it should be fully open if things are set right. Also when in gear at idle the rubber stop should just be a hair off of carb pick-up shoe. Keep an eye on starter bolts they get loose and break the engine casting. 2 drops of oil on starter bendix to help gear engage. Good job on rev lock, rookie."
