Hi Merc guys....
I post regularly on the J/E forum, but now I have this Merc that is giving me fits.
It came to me not running. New to owner, never test ran it, nothing.
I checked compression....150 range on all four.
I checked spark. No spark. Debugged it to a bad switchbox, replaced, now good spark.
Ok, so....went thru the carbs (2) and found some usual things, cracked bowl gasket, missing drain plug gasket, floats not quite right but close, nothing real major. I replaced the welch plugs and sealed them with Indian Head shellac.
Set the floats with the float arm level with the bottom of the carb body, by adjusting that 1" long arm that goes over to the needle.
Re-installed the carbs, started it up.
Here is the problem: It will NOT idle any lower than 2500 RPMs. I have a tach hooked up.
I have indexed the flywheel and all sparks are happening at the proper time for all four cyls. 1-3-2-4 firing order.
I have fixed the timing lever (tied it down so it cannot move) at exactly TDC position for the timerbase.
Both throttle butterflies are absolutely closed and in sync. It should idle normally with those settings.
I have actually disconnected the carb butterfly linkage so that the butterflies cannot open.
I have looked up at the sun thru the carb throat, checking for butterfly sealing/closing all around the throat.
All checks out.
The engine is on my test stand, with the lower unit removed, and being fed water via a hose up the water tube.
The fuel line is plumbed directly to the carbs, bypassing the fuel pump. The primer bulb gets firm as it should.
No gas leaks. I put the fuel line directly to the carbs to eliminate a torn fuel pump diaphragm.
After running it, large amounts of unburned fuel and water mix drip out the bottom of the midsection onto the floor.
Tells me it is way, way too rich.
It has that weird enricher valve that turns to enrich for choking. (no choke butterflies) I have been thru that and cannot find anything wrong.
Idle mix screws are set at 1-1/2 turns out.
Directly in the front of the carb throat, off to the right, is the idle air bleed orifice. I am measuring that as about .038" in diameter.
I can plug that orifice with a toothpick. If I plug either carb's idle air orifice, the engine runs on the other two cyls. If I plug both orifices, the engine dies. That tells me the extra fuel is coming from the idle circuits of the carbs. Is this a fair conclusion?
Where can all this extra gas be coming from? Why is it pulling so much gas that it revs up to 2500, does not flood/choke itself out, etc.
It almost seems as if it is getting gas and some air to keep from flooding out.
I have sprayed carb cleaner all around the intake, carb mounting gaskets, etc....no detectable difference looking for a leak somewhere.
Is there some quirk about a Merc ignition system that can cause this racing condition even tho the timing lights show everything is OK?
Does it need the LU on it to provide back pressure to slow it down? Even so, that crap dripping out says rich unburned fuel...
I am tearing my hair out.
Any Merc experts out there that can lend some advice? Much thanks.....
All checks out.
