Hi guys i have had my outboard for the last 14 years and dad had it for 20 years before me, it has served us really well a truly great motor but recently i 've noticed a problem with it and would like your thoughts on what i should do next,
outboard has good compression 120 (+/-) 2, idles perfectly and great low speed but once i push the throttle past 3/4 way it does nothing more. i suspect that the stator may be a problem (HIGH END WINDING).
i have measured the resistance of the stator leads and the results are as follows
red/white to red= 63 ohms, blue/white to blue= 6600 ohms (i believe red/white to red should be around 145 ohms)can somebody in the know please confirm, its a sierra stator.
I decided to take some DVA readings I built a dva adapter and connected it to my multimeter these are my readings with outboard at idle and given some revs
red/white to red =121 volts, blue/white to blue= 301 volts. at the power pack feeding the coils all read @ 250 volts.
I have read that voltage of red/white to red should not be lower than blue/white to blue is this true and is 120 volts too high, spec states 20v +
