Mercury 15hp high speed problems
oyster78
i am having problems when i op
i am having problems when i open the throtle to wot it wants to bog but if i let off just a little it is fine all the way to idle wondering if anyone else has this problem? it is a 2stroke.
have cleaned the carb and rebu
have cleaned the carb and rebuilt it but it has a small crack in the middle part of the fuel pump the part with the timing stop screw could that cause the problem?
"David,
check to see if your
"David,
check to see if your butter fly inside of the carb is level at wot. i have seen on some sometime if it's not ajusted right that it would actually start to close going to far."
yes it could did you rebuild t
yes it could did you rebuild the fuel pump if you took it apart you must replace the diaphragm and gaskets
