Hey Guys I am new to the forum. I am having a few problems with a 95 Mercury 115 4 cyl. that I am hoping to get some ideas on. The motor will run rough at idle, run rougher in gear at low idle and to 1800 to 2000 rpm and then will smooth out a bit, it is weak out of the whole and when at WOT it surges. Now for what has been done to solve the problem. I took the motor to a boat mechanic. He ran a compression and spark test said everything was great with both spark and compression. He cleaned and rebuilt the carbs and fuel pump. He replaced the fuel lines from the tank to the motor, replaced the fuel filter, replaced the a.s valve, replaced the plugs and plug wires and checked for air leaks. I get the boat back still the same problem, so I notice the rpm gauge running about a 1000 rpm higher than normal, I then replace the regulator and while I was at it I decided ( for preventive maintenance purposes ) to go ahead and replace the ignition components as in the stator, trigger coil, ignition coils, and switch box. I still have the same issue after all of this. The idle/air adjustment has been redone over and over according to the service manual, still the same results. Anyone have any ideas? Oh yea from time to time, say once in a blue moon the motor will take a notion to run like a dream been a while though.
