I have a 1969 mercrusier 160. Engine has been professionnally rebuilt and I did the removal and install. after 2 years it suddenly quite.
Replaced the ignition switch, ballast resister, and coil. It has a Mallory electronic distributor kit in it. no points. Now, with the key in the on position, I have 12 volts at the starter, 12 volts going to the ballast resister, 5.94 V. at the positive side of the coil and going into the distributor. Removed coil lead to check spark. When key is turned from on to start, it sparks once, then ,continues to turn over but no spark, when key is released from start back to on position , it sparks one more time. thats it,?? nothing in between
Something with the starting system and run systems ?? any ideas
