Island_Hopper
We are having trim problems on our Bravo 3. Goes up well/strong to correct extension length. Won’t go down (for a while it would go about an inch down, but now won’t do that). 2015 drive with about 250 hours. Pump motor spins when trying to go down. Sounds normal so no solenoid issue. Fluid level is correct. Can’t stand on drive to get it down because of swim platform. Rams appear undamaged. This happened when we were in water. Once we started forward, the motor eventually worked its way down, but became stuck up again when testing on shore. I am going to remove the rams to ensure they operate normally with no load, but the drive is up and want to get it down before doing that. Any suggestions on what the problem might be? Will releasing the hydraulic pressure lower the drive if gimbal not stuck? Has anyone had a failure of the valves associated with the pump that caused this? Thanks
