Anything can be fit to a Bravo drive. You will need the correct gear ratio for your diesel. Possibly the same ratio used with the Merc/Cummins B4 engine.
Are you replacing a Merc engine with a Volvo engine or is your boat originally Volvo and you want to install a Merc drive?
Hi,
Is it possible to fit a Mercruiser Bravo 1X outdrive onto the Volvo engine? If so, what are the steps and the potential pitfalls?
You will need a Merc flywheel cover (bell housing in the auto world) that will mate to the TAMD 31 Diesel engine.
You will also need a rubber hubbed drive coupler that will mate to the diesel engine.
Far as I know Volvo uses regular old GM engine so yeh it'll go. Prolly need to put the mercruiser flywheel housing on there. Drive coupler on Volvo is some weird thing so count on that too.
Volvo Penta uses an industry standard, all steel, Borg Warner drive coupler. The same drive coupler found on many inboard transmission installations.
Otherwise all the bravo stuff should bolt right up. Transom hole should be same.
The TAMD31 was used in both I/B and/or I/O scenarios......... if I/O, it would be one of the AQ series drives in either the s/p or DP version.
(OP says 1.79:1 reduction..... so its a Duo Prop drive)
Since the OP is wanting to change to a Merc B drive, he needs to know that the Merc transom unit will require the transom cut-out to be in-filled and re-cut to the smaller size!
Or.....use the adapter plate that you can find.
You may have to drill for the two upper studs as I think Volvo doesn't have those.
I'm sure Rick the Marine wunderkind will report in shortly and overanswer this for you.
Yes, I will "over-answer" in hopes that the OP has enough information in order to make an educated and informed decision.
OP says that the ratio was 1.79:1 (of which is actually 1.78:1 and is a Duo Prop ratio)
If going from a Volvo Penta DP to a Merc B1, someone will need to do the math.
Chris, as I understand it, he now has the TAMD 31 with the AQ series Duo Prop drive and is asking about installing a Merc B1 behind it.
Thanks, the boat had a Volvo outdrive but it broke spectacularly and we've decided to put on a Mercruiser drive in its place... mainly for cost and availability of parts... the old outdrive ratio was 1.79 but I'm not sure what the Bravo is.
The Merc B drive transom unit is considerably smaller than the AQ series transom shield.
In order to use the Merc B drive on a transom that is set-up for an AQ series Volvo Penta, you will need to have extensive structural transom work performed.
Or..... there is an adapter plate that can be used.
I would strongly suggest staying with the Volvo Penta AQ series drive that you now have, and do the necessary repairs.
With the AQ series:
No annual engine drive coupler alignment check/adjustment in lieu of fixed geometry.
All steel Borg Warner drive coupler in lieu of a rubber hubbed drive coupler.
No Gimbal suspension system in lieu of main suspension fork/pivot tube geometry.
No Gimbal bearing in lieu of fixed PDS and bearing arrangement.
No thru-prop exhaust outlet.
Very user friendly drive shaft bellows replacement.
The larger foot-print of the AQ series transom shield places FWD thrust torque over a greater area of the structural transom.
Perhaps the deciding factor will be availability of parts and service for you.
Our original Volvo outdrive was an SX-M1.
I will take some pics n post them when its done... fingers crossed!
Your Flywheel housing needs to be swapped but the coupling can be used on the Mercruiser as the input shaft is the same diameter and spline
We're trying to find replacement parts and the yoke is affordable but the damper replacement is a Volvo part (3858749) and upwards of $1,400! Do you know if there's a Mercruiser alternative which will work or will we have to fork out for the Volvo part?
Ayuh,...... Are you callin' the coupler, a vibration dampener,..??
If so, it depends on how it mounts to the motor,.....
If it bolts to the crankshaft, ya gotta match that bolt pattern,.....
Late model Merc couplers mount to the flywheel, in the standard pressure plate bolt holes found on standard Chevy flywheels,.....
'n just how did what you've got fail,..??
If it ripped out the splines, it's probably not engagin' enough(depth) of the splines,....
It should engage a full 2" of splines,.....
Re:...There was only one prop being used so perhaps it wasn't the original outdrive on this engine, or it had been adapted previously..."
Perhaps this was a contributing factor in the "spectacular failure" of the Volvo... Spectacular Volvo failures usually relate to the drive not being maintained properly ( incorrect or no lube) or hitting something hard at speed. Neither one of which are inherent Volvo issues.
- suspect no lube..
Hi Ricardo,
I think this is where we might be going wrong - I'm not sure the splines on the Mercruiser Bravo yoke mate with the Volvo coupler/damper.... can you confirm?
Thanks a mill
