strokin898
replaced starter and slave have good wiring from dash but when i turn the motor over it won't stop until i pull the battery cable. please help summer is getting shorter!!
Are you speaking about the starter slave solenoid or the solenoid attached to the starter? The wiring on the slave has stripes. You need to provide the wire colors exactly as they are on the engine. It sounds like you have the starter/solenoid wired wrong or two terminals are touching together on the starter.
...then connected large yellow wire to left large terminal which goes to the inside terminal of starter solenoid itself.
