2000 Mercruiser 5.0 V8 with 2bbl carburetor.
I have an intermittent surge I'm trying to track down. Sometimes the motor seems slightly sluggish off the start but most often it does fine. While running about 3500RPM it will occasionally lose a couple hundred RPM then pick back up to 3500. It never sounds like a misfire and there is no backfire or sputtering. Oil pressure and water temp are great with no unusual fluctuations.
Could this be a fuel pump not delivering sufficient volume? The filter was new this spring so I think that is fine. If it is the fuel pump, what are the steps to diagnose that issue? I've looked up prices and a new pump is $250, so I'd rather not just throw a new pump on guessing at the issue.
With the lack of sputter or misfire I"m hesitant to think it's an ignition issue. But, if it were an ignition issue, what components should I start tracking down?
Thanks,
kevin
Thanks,
kevin
