Dougalsdad
Engine 4.3LX, V6, 205hp
Serial number 00804444
Build 1992
1992 Searay 220 OV
That's the engine data, it's serviced every year and runs really well, usually.
Last year it had new headers, water pump and thermostat.
It starts easily and runs nicely straight off the trailer.
At first it runs really well and sounds good.
After running at 3,200 rpm for about 25 minutes it misses for a short while, coughs and then backfires. I think the backfire is back through the carb as it is very loud, quite a bang.
The engine loses power and then runs very roughly and won't achieve normal rev's.
It then continues to cough and backfire.
The engineer took it for a test run this week, ran it at 4,000 rpm to put it under stress and could not get it to misfire at all.
We took it out again today and the same problem was there.
My thoughts are that as the coil, distributor cap, rotor arm and HT leads are the original items then it's probably an electrical problem. My best guess is that either the distributor cap is breaking down after running for a while or the leads are breaking down so the HT is taking the path of least resistance causing the backfire.
I have cleaned the distributor cap and sprayed it with water repellant but it has made no difference.
I doubt it's a fuel problem as the boat starts, runs and accelerates fine for the first 25 minutes.
I'm planning to replace the cap and arm first as they have the lowest impact on my wallet, everything else just starts to get expensive.
Any suggestions would be very much appreciated.
Build 1992
1992 Searay 220 OV
