jmiles8701
I have an 87 glasstream with 3.0L mercruiser and alphaone outdrive. my issues started with the boat having trouble starting, it would turn over but not fire. then came after it would start and you attempt to accelerate the boat would skip and miss and back fire out of the carb, same when decelerating, but once able to get going the motor ran great from about 1/4 throttle to WOT. now its gotten worse. the motor wont start at all unless you give it a bunch of gas. once it does start you have to keep it near about 1/2 throttle to keep it running, any change and the motor will instantly start missing and backfiring out of the carb and stall. today I removed the carb and gave it a good cleaning. put it back on and don't see any improvements. obviously I will do a tune up on it asap (plugs, wires, cap, rotor,) but I wanted to post on here to see if I could get any help. my thoughts are to add a water separator, and drain the fuel tank to eliminate the possibility of water in the fuel. any other ideas?
