1982 Mercruiser 260. When I fired up the motor this spring it ran and sounded fine. Launched the boat, initially leaving the ramp and idling to channel it was still fine. 20-30 mins on a plane at 3000 rpm, then when I backed down to idle or anything less than about 1500 rpm I get a "knocking". Fearing the worst, I started pulling plug wires to isolate the bad cylinder. No changes in Knock when any of the plug wires were pulled. (I have successfully used this diagnostic trick on Chevy V8s before).
When I pulled #8 wire there was no change in engine rpm, as opposed to pulling #1 which causes dramatic change. Swapped #8 wire for #7 wire and there was no change. Like #8 cylinder dead. Changed plugs, cap and rotor. No change in knock. Ignition is a Pertronics point-less setup.
Here's what really has me puzzled...Today while troubleshooting, I pulled #2,3,5,and 8 plug wires all at the same time with very little change in engine rpm (maybe 50 rpm).
#2,3,5,8 are all on the same lower plane of the dual plane intake manifold. Is it possible I have a plugged idle circuit in the Quadrajet 4 barrel carb? The engine runs fine above 1500-1800 rpm with no knock or any lack of power.
Anyone ever seen or heard of this? Sure could use some input.
