My 1989 boat has a 4.3LX,Alpha One,Thunderbolt ignition> it has a Rochester Quadrajet carb and ran perfectly for 20 years. The last two years have been nothing but trouble. At startup and through most/all of the RPM range it seems to be running way too rich. You can see the gasoline on the top of the water and smell it when it is running. The carburetor was replaced twice with a remanufactured carb, current one has serial number 17058213, and it seems unchanged. It has a remote choke which seems very slow to open but the engine still seems to have trouble even if I wire the choke open.
After three carbs (original plus two remanufactured), I am starting to think that either the supplied carburetor (both from the same source) is not correct for this engine or bad ignition is making it look like over-rich since it is not really burning correctly. I have changed the coil and the distributor and cap - no effect. I measure 12 volts at the coil when the ignition key is on but it drops to about 9.5 volts when I crank the starter. After it starts, the voltage is back up at 12 volts.
When we borrowed an original carburetor from a similar boat and installed it on my engine, the engine seemed to run fine.
