I have a Mercury 90HP ELPTO S# OT816037 on my bass boat which was acting strange at the end of last year. The dash voltmeter would drop to ~12V at higher speeds, say >4000rpm. When I slowed to <4k, it jumped up to14-15V. This got worse until the end when it would only charge at <1200rpm. Also, when not charging, the dash gauge would pulse at a ~1/sec frequency!!!!
This year I looked at it more closely and measured ~35V at the stator input wires of the voltage regulator, using a digital voltmeter. The regulator output measured a constant 12V. Believing the regulator was the problem, I replaced it (Part #883072T) BUT the readings did not change!! For what its worth, I also measured the voltage at the dash with the DVM and it varied from 12 to 13V at variable rpm.
Does this make sense to anyone? Has anyone heard of a pulsating dash voltmeter? What would you suggest I do next, find a repair shop?
