"Well If you have to ask then
"Well If you have to ask then we may need to tell you.
Remove the Flame arrestor ( air cleaner ).
Look straight down and that black thing about the size of a old square telephone that is the CARBURETOR.
There are 2 halfs to the carb. the front half is the half with the choke. it is a very thin plate that should close when the engine is COLD and you move the throttle to activate the linkages.
This choke is controlled by a small group of squirrel, opppps I mean a small round black device on the left side of the carb. There is a bymetal spring inside there. There should be two wires going to it, purple and black.
When closed/cold the choked should almost close completely and after the key is on for a while the metal spring inside that black cover heats up and the choke should open all the way. (all the way is completely vertical)"
