"Hi. Have a 1997 engine Mercru
"Hi. Have a 1997 engine Mercruiser 5.7 with Thunderbolt V Ignition, 2 barrel Mercarb. Problem is the boat run perfectly for about 20-30 minutes and then starts to loss power, backfires and while not run over approx. 1200 RPM. This is very repeatable. After it heats up for 20-30 minutes runing at 32000 RPM in gear. Shifting to nuetral after problems starts and reving engine, all is fine. Put back in gear and under load and it immediatly loses power and backfires and pops from carb. Let it cool down for 30 minutes and all is fine until it heads back up after 20-30 minutes under load. It appears to be heat related. Some folks have told me it maybe ignition problem with Coil, optical sensor in distributor or ignition module. Module is very expensive. I don't think its fuel related. Can a Merc dealer test the ignition module? Problem is very repeatable but baffling to find solution.
Any thoughts on what is causing the problem?."
