Throw that dang Selco manual away..... when the key or kill switch is activated it sends the capacitor charge from stator to ground...nothing thru/from trigger.The blk/yel wire is connected to the trigger signal emanating from the stator under the flywheel but physically connecting inside the CD module. It shorts out (to battery -, aka ground) the trigger such that the SCR that would normally conduct, shorting out the pulse capacitors and causing a spark to be delivered to the plugs, doesn't occur.
