Hello All,
Recently installed new merc 5.7 carb, alpha with HEI ignition and 4 barrel 1409. Vortec motor.
Boat is an 02 Bayliner 2252 I rescued from the scrap yard. Brand new drive as well.
once dialed in and broken motor seems to run great (although I think I'm over propped at the moment. She only sees 4200 and 34 mph.
Although I'm not ruling out carb or fuel issues, every now and then she just does as if the kill switch was hit. No sputter no stumble no backfire. I believe it's electric due to the way gauges bottom out momentarily.
Side note it was doing this regularly until I completely bypassed the facory engine harness plug. Must have had a short or poor connections. Everything on the engine side of the harness has now been replaced at this point with the exception of the main ground splice within the factory engine harness.. Next attempt will be to run new purple wire to helm, and new main power feed.
Although I may be answering my own questions here would a bad fuel/water separator be a cause of these symptoms? I would expect it to behave differently if so.
With the HEI setup, do they cut out completely at a specific voltage?
