After the numerous warranty-covered issue of fuel starvation, blamed on Southern climate(Florida) and ethanol, the Tohatsu installed a transom-mounted fuel pressure booster unit. This worked, although not perfectly 100% of the time. They eventually upgraded to a more powerful unit to replace the initial after further, continual dealer bringbacks. Very frustrating experience to say the least, although Tohatsu has admitted to several other motors having same issue.
Recently, now, out of warranty, I have developed a startup issue...although this only happens intermittently, while out fishing. The "on" position has its typical audible and visual cycle before silencing, the start position will yield ZERO. Removing the 15A fuse(pt/t & ignition) to examine yielded 0 visual break. I reinserted same fuse and it then started. This was occurring while fishing about 20 % of the startups. I coated all fuses(with factory rep recommendation) with dielectric grease. While out fishing yesterday, it only happened twice, but still a pain in the arsenal!
BTW, I have tried new fuse replacement with same results.
Thanks in advance
DJD
Thanks in advance
DJD
