I wonder if anyone can help me with a strange problem. Firstly I received this outboard because it was old and leaking badly. Not only from the carburetor, but also from the tank which was rusted through in a few places. After repairing the tank, I was able to use it for short runs but it would flood the carburetor if I left the tap open when it was not running. At the beginning of the year the carburetor bowl broke and I was unable to replace it as the motor is obsolete, so I turned a new one on a lathe and redirected the overflow out of the side. I also turned a new seat jet which now stops the carburetor from overflowing. I am now able to leave the tap open, and after 24 hours am not getting any overflow. The motor runs well with no problems while idling in or out of gear.
The problem is that when I leave the moorings I can go at full throttle for about 100 meters and then I loose power. After that I can keep going as long as I keep the revs low. I have managed to run for 1 nautical mile if i stay under three knots. First thought was that there was not enough fuel getting into the carburetor and it was starving for fuel. Today I turned a new bowl out of white HDPE and made side walls thin enough so I could see the fuel level (1 mm). Once again I managed to get about 100 meters before it looses power and then must stay at low revs to keep moving. The level in the carburetor has not dropped below normal and the flow of fuel stays constant.
Does anyone have any suggestions?
