taylor6632
Hi,
I've got a lovely 14' 1980's broom ski boat which i'm restoring. I'm fine doing the GRP work and interior but the engine is proving to be a bit of a pig with the wiring! It runs fine and had complete carb strip and rebuild, bit of rattle in top end but told its the normal sounds of an engine like this.
Anyway, I'm trying to get hold of a simple wiring diagram or a list of what color wires go to what! I want to install a tach (not the wrap around spark lead job, a proper one) so am trying to find the tacho wire. Had some info that suggests maybe grey or yellow or green. Both the grey and yellow are coming out of the CD ignition unit but neither head up the main loom to the control box. (I will add that boat never came with tacho so might not have been run up to control). The grey wire connects to one spark plug lead along with an orange wire to the other. The yellow wire heads of under the flywheel to what i assume is the charger circuit?
Any info would be amazing as i'm at a dead end now....
