buster brown
I have just bought a 50hp Mariner and serial number appears to be O9776280-any body tell me the year please and model number etc for ordering parts and servicing?
Are you sure that is the right number or that your engine is a 50 hp?many thanks-I think the number is in fact OG 776280-would that be correct ?
Cliff, Is that part of your new program you were talking about? Nice. You should be able to punch in the serial number and it should take you right to the info you are looking for.Hello Buster,
I'll take a swing at this, I believe that the serial number is incorrect here is a image can you recheck and verify yours please.
That serial number comes up as an 1999 MERCURY SEA PRO 75 MLH, Serial No: 0G776280 Model No: 1075217VD (3 Cylinder)
Service manual #90-830234R04 - 75/75 MARATHON, 75 SEA PRO, 90/100/115/125 - 65/80 JET
Somewhere on the cylinder block there should be a plug with the serial number on it. See pic for example.back to the drawing board-where do I find the serial number ?
The decal on the engine cowl say 50hp Mariner !!!
IT IS 3 CYLINDER BUT i DON`T KNOW WHERE IT WAS MADESorry, But my system is not picking up any information from your 9776280 number.
The system I use does not pick up anything older than 1980ish or anything made out side the of the USA.
Do you know where the engine was made? Is the engine a 3 or 4 cylinder?
I'm unsure of your engines year, But with the info you have posted shows this link will be a starting point for you to be able to look up your engine parts that fall within your engine serial number. 9683055 THRU 9885344 (This Links For Example Only.)Hello Buster,
Thanks for the info, For some reason I have a hard time remembering different names out side the U S of A.The B is for Belgium,and if the number begins with 9 it it's Belgian.
In the website you posted, I see his engine as a 93. Serial number 50 HP, 0971000 - 09793444 = 1993
